Printing Issue
mathew.p
(@mathew-p)
Printing Issue
Hi guys,
Im trying to print PLA on the normal default prusa i3 setting ands the layers are coming out terrible.
Have checked:
Belts and pulleys,
have also changed out the nozzle
Extruder motor keeps clicking as it prints.
Am lost on what to look at next.
Cheers
Veröffentlicht : 14/02/2016 2:15 am
richard.l
(@richard-l)
Mitglied Moderator
Re: Printing Issue
I fought this problem this morning. My problem was incorrect tension on the filament feed screws. There was enough difference in filament diameter between two different colors from the same company that it created the exact same issue as you.
Veröffentlicht : 14/02/2016 4:53 am
mathew.p
(@mathew-p)
Re: Printing Issue
Clicking solved but still have the weird extrusion problem.
You were right about to much tension on the screws, thank you.
What size is the pt tube inside the extruder and is there a guide on how to change this somewhere?
Veröffentlicht : 14/02/2016 9:42 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Printing Issue
Hi Matthew
First use the "Atomic Method" to clean the extruder (from point 3): https://ultimaker.com/en/manuals/149-atomic-method
This will give you an idea of how clean the insides are. If you see any black bits coming out with the filament, then chances are that the PTFE tube is burnt and blocking the filament path.
Josef posted on here recently about this and the possibility of running with a shorter PTFE tube if you don't have any spare (search his posts for "PTFE"). PTFE is 4mm OD and 2mm ID.
Peter
Veröffentlicht : 14/02/2016 11:08 am
mathew.p
(@mathew-p)
Re: Printing Issue
Thanks i found your link to the atomic guide yesterday and tried it and was unable to remove the filament once the head cooled to the cooler temperature.
I found the guide josefs guide on changing the tube and pulled it out and im guessing its not supposed to look like this.
I have ordered some more and will replace it.
Veröffentlicht : 15/02/2016 12:26 am
PJR
 PJR
(@pjr)
Re: Printing Issue
Hi Mathew
You are correct in that it should not be burnt like that. Apparently, it is possible to cut the end off and still print, leaving it short at the top end. You just have to ensure that the filament loads properly before printing.
Its best to have some spare tubing available, as this can happen. I have found that running out of filament during a print can cause it, but not always.
Peter
Veröffentlicht : 15/02/2016 9:49 am
