printing issue
pau
 pau
(@pau)
printing issue
hey guys,
i got a problem with the pint.
what i have to do?
i wanted to print the maker fair robot http://www.thingiverse.com/thing:539127
and i use for this pla from polymaker
Opublikowany : 12/01/2017 1:28 pm
david.b14
(@david-b14)
Re: printing issue
It looks like the back started to curl up, so I would start with adding a brim.
Opublikowany : 12/01/2017 2:13 pm
pau
 pau
(@pau)
Re: printing issue
did you mean: i should add a brim on/to the model?
hmm a lot of other guys printed this robot with the prusa mk2 to. i think i calibrate something wrong.
but i'm a newbee in 3d printing. and the prusa is my first printer.
Opublikowany : 12/01/2017 3:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: printing issue
You could also try increasing bed temp and reducing the speed.
Peter
Opublikowany : 12/01/2017 3:56 pm
pau
 pau
(@pau)
Re: printing issue
i tried that filament the first time.
so maybee the setting for the filament a wrong?
so there is no issue with the z-axis?
where do i setup the printing speed. do i have to do that in slicer? but there are so many field. which one should i take.
perimeter
small perimeter
infill
Opublikowany : 12/01/2017 4:13 pm
Nick
 Nick
(@nick-19)
Re: printing issue
I would say turn the heat of the bed up to 63-65, also might be worth checking out your bed level also in case is slopes down at the back.. However.. has something happened to the right side of your bed?
Opublikowany : 12/01/2017 5:41 pm
pau
 pau
(@pau)
Re: printing issue
yes, when i calibrated the printer. the bed wasn't leveld. so the right side was a up.
i think only the foil is damaged at this point.
thank for all oyur help.
i will start a new print tomorrow morning
Opublikowany : 12/01/2017 7:28 pm
Re: printing issue
When I printed the same model, I added supports, because the shoulder of the arm tipped up and caused shifted layers, and I printed the first layer thick and slow... .3mm with a display sped of 60%
and it worked for me...
Opublikowany : 12/01/2017 10:38 pm
pau
 pau
(@pau)
Re: printing issue
thank you 🙂
Opublikowany : 13/01/2017 11:44 am
Carsten
(@carsten-2)
Re: printing issue
Yes there is a version with supports build in: http://www.thingiverse.com/thing:539127
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Opublikowany : 13/01/2017 4:00 pm
