Printing issue
CorpseGuard
(@corpseguard)
Printing issue
Hello there.
I want print a spoolholder but please take a look at the pipe which should hold the Spool. Its look not good.
Someonehad an idea what the poblem is? I am using Simplify3D.
I use the original Prusa settings and printed with 0,3mm Layer and 60mm/s printing speed.
The second one i tried with 40mm/s and 0,2 layer high. But the same issue.
Napsal : 23/04/2017 8:41 pm
Re: Printing issue
I printed some rifle scope sun shields, which are mainly tubular, and I found that if I slowed the print, I got less zits...
if this is a tube, can you print outside to inside rather than the other way?
regards joan
Napsal : 24/04/2017 1:25 am
