Printing fails after half of the time
Andreas K. B.
(@andreas-k-b)
Hallo,
please look at the attached files. Has anyone an idea what is going wrong with this print.
I use ColorFabb PLA.
Thank you very much!
Napsal : 21/03/2018 4:26 pm
MechLink
(@mechlink)
Re: Printing fails after half of the time
If you could post the model file and a picture of how its placed on the bed along with
print settings such as supports, layer height, etc that you are using that would help.
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Napsal : 21/03/2018 7:50 pm
Andreas K. B.
(@andreas-k-b)
I hope these are the details you need. Is there any possibility to upload the .stl or the printer .ini file (with all settings etc.) ?
Napsal : 22/03/2018 9:01 am
MechLink
(@mechlink)
The settings look fine for the if you are using the ColorFabb PLA PHA.
You should be able to attach the .stl file to this page if not you can use something like Dropbox and share the link.
Have you tried the same print but with any other Filament?
Also check you extruder and try running a "self-test" on printer to see if anything comes up just to be sure.
here is a link to help maintenance your nozzle https://help.prusa3d.com/l/en/article/WWVRzOY1dX-clogged-nozzle
See my stuff at
Napsal : 22/03/2018 4:51 pm
Nikolai
(@nikolai)
Hello Andreas,
You are the only one who can watch it printing and see the reason why it's failing.
We can only guess. What exactly is failing? Is it clogging? Layer shifting? Just stops and resets?
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 22/03/2018 5:28 pm
