Printer parts files? [SOLVED]
I would like to print some backups. Anyone know where to find these files? Are they the same for every current i3?
Re: Printer parts files?
Hey pietro.g!
It dependence of what i3 you have, if you have i3 from our shop (shop.prusa3d.com) you can find the current version of *.stl files on following link http://www.prusa3d.cz/wp-content/uploads/prusa-i3-stl.zip
The most of parts are remaining the same, if you'll find that it's not matching your printer, post pictures of your printer and we'll post the *.stl files here or you can try to find it on github https://github.com/josefprusa/Prusa3-vanilla
Cheers!
Michal Prusa
CTO
Re: Printer parts files? [SOLVED]
I would like to import the Aluminum Frame into my SketchUp program so I can get the exact position of the drilled holes. Can you convert and upload that file so it will import? The GitHub Vanilla has a alu-frame.dxf but that does not play well unless you have AutoCAD.
Hi, you can use free QCAD. That's what I use for designing the DXF files 🙂
Thanks! I'll try it!
Lastly, please tell me that file has the exact hole positions with the unit I just purchased.
Thanks 🙄
Hi, this is the production file https://github.com/josefprusa/Prusa3-vanilla/blob/master/src/alu-frame.dxf
Thanks!
I am having a hard time with that tool. Can you Please convert that alu-frame.dxf to skp file for me?
Hi
I would like to print also some spare ones.
Which settings are the parts originally printed with?
Thanks
We use normal and print multiples at a time 🙂
Thanks a lot. 🙂
