Printer parts files? [SOLVED]
pietro.g
(@pietro-g)
I would like to print some backups. Anyone know where to find these files? Are they the same for every current i3?
Respondido : 12/06/2015 12:41 am
michalprusa
(@michalprusa)
Miembro Admin
Re: Printer parts files?
Hey pietro.g!
It dependence of what i3 you have, if you have i3 from our shop (shop.prusa3d.com) you can find the current version of *.stl files on following link http://www.prusa3d.cz/wp-content/uploads/prusa-i3-stl.zip
The most of parts are remaining the same, if you'll find that it's not matching your printer, post pictures of your printer and we'll post the *.stl files here or you can try to find it on github https://github.com/josefprusa/Prusa3-vanilla
Cheers!
Michal Prusa
CTO
Respondido : 13/06/2015 8:10 pm
K6TJO
(@k6tjo)
Re: Printer parts files? [SOLVED]
I would like to import the Aluminum Frame into my SketchUp program so I can get the exact position of the drilled holes. Can you convert and upload that file so it will import? The GitHub Vanilla has a alu-frame.dxf but that does not play well unless you have AutoCAD.
Respondido : 24/06/2015 1:52 am
Josef Průša
(@josef-prusa)
Miembro Admin
Hi, you can use free QCAD. That's what I use for designing the DXF files 🙂
http://www.qcad.org/en/
Founder and owner / Majitel a zakladatel
Respondido : 24/06/2015 2:27 am
K6TJO
(@k6tjo)
Thanks! I'll try it!
Respondido : 24/06/2015 3:39 am
K6TJO
(@k6tjo)
Lastly, please tell me that file has the exact hole positions with the unit I just purchased.
Thanks 🙄
Respondido : 24/06/2015 3:41 am
Josef Průša
(@josef-prusa)
Miembro Admin
Hi, this is the production file https://github.com/josefprusa/Prusa3-vanilla/blob/master/src/alu-frame.dxf
Respondido : 24/06/2015 1:54 pm
K6TJO
(@k6tjo)
Thanks!
Respondido : 24/06/2015 3:46 pm
K6TJO
(@k6tjo)
I am having a hard time with that tool. Can you Please convert that alu-frame.dxf to skp file for me?
Respondido : 24/06/2015 11:31 pm
laszlo.i
(@laszlo-i)
Hi
I would like to print also some spare ones.
Which settings are the parts originally printed with?
Thanks
Respondido : 06/08/2015 2:34 pm
Josef Průša
(@josef-prusa)
Miembro Admin
We use normal and print multiples at a time 🙂
Respondido : 06/08/2015 3:56 pm
laszlo.i
(@laszlo-i)
Thanks a lot. 🙂
Respondido : 06/08/2015 6:16 pm
