Printer misaligns X-Axis and Squirts out weirdness
chris
(@chris-56)
Hi all,
I've created the following video.
I don't know what has changed, but suddenly the printer only produces this:
https://drive.google.com/file/d/0B8JhVrqZMbFEd2JBdGNwNmVRSEE/view
(Video)
If anyone knows, thanks.
Kind regards,
Chris
Postato : 03/07/2016 3:52 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Printer misaligns X-Axis and Squirts out weirdness
Most likely the one or both of the belt pulleys is loose. Can you check those please?
Peter
Postato : 03/07/2016 9:49 pm
chris
(@chris-56)
Hi Peter,
thanks for the reply, but as seen in the video, the belts are quite tight. I will however check the one on the bottom (Y-Axis) as well.
Kind regards,
Chris
Postato : 03/07/2016 10:50 pm
Cipis
(@cipis)
Utenti
PJR meant pulleys on motor shafts, not belts :-). And he is propably right.
Postato : 03/07/2016 11:01 pm
chris
(@chris-56)
Hi Guys,
first up .. thanks a lot for the help.
Will now re-check the metal wheels as well.
I figured out what the problem was... printing dirt had accumulated on the bed's sliding rods... that got the bed stuck...
Issue is closed... will open a new one next time i get stuck..your support was great.
Kind regards,
Chris
Postato : 04/07/2016 4:30 pm
