Printer/Equipment help
mickey.s
(@mickey-s)
Can anyone help me? I don't know my printer is not printing correctly. I ran the calibration test, recalibrated XYZ and still looks like this. http://imgur.com/a/Try8V
Napsal : 08/12/2016 2:48 am
StephanK
(@stephank)
Re: Printer/Equipment help
Did you try to decrease the distance between your nozzle and the bed using the live adjust-z feature while it was printing?
Napsal : 08/12/2016 4:27 am
mickey.s
(@mickey-s)
I did, i ask tried to add glue to the plate, it helps a little.
Napsal : 08/12/2016 6:52 am
StephanK
(@stephank)
Well, judging from the picture it needs to go a fair bit further down. If this is PLA, there should be no need to use any glue.
I'd try the following
- Thoroughly clean your bed with the included alcohol wipes or Isopropyl alcohol on a paper towel
- Redo a Calibrate Z just for good measure (optional)
- reprint V2calibration
- and while it is printing lower the distance even more using the live adjust-Z.
Napsal : 08/12/2016 11:08 am
mickey.s
(@mickey-s)
Ok thanks you. I will try both when i get home
Napsal : 08/12/2016 2:21 pm
