printed plate (sheet...) is peeling of
jean-paul.b2
(@jean-paul-b2)
Hello everybody !
Newbie in 3D printing ... I realise my first attempts... and quite happy for the moment. Thanks to Josef and his team for that nice product !
My printer : MK2S KIT.
I did print TREEFROG successfully... and some other little pieces in PLA.
Can you help me to solve this Issue... it is my first attempt with ABS.
https://photos.app.goo.gl/WPO2KB6UD3FDMjG13
This is the base of something like a box. That layer is suppose to be 2mm thick. As you can see, the layer peel of on one corner after printing +/- 1 mm.
I use ABS (brand : Sienoc) and choose these options in PrusaControl before printing : Generic ABS, Quality : Normal, Infill 20%.
Can you help me ?
Thanks by advance!
Jean-Paul (Belgium)
Veröffentlicht : 29/12/2017 12:51 pm
vaxxi
(@vaxxi)
Re: printed plate (sheet...) is peeling of
You need to use the brim support option, at least 5 mm I'd say.
https://rigid.ink/blogs/news/3d-printed-raft-brim-skirt
Also, make sure the room is quite warm and air temperature is constant (do not open doors, windows to the outside for example).
Veröffentlicht : 29/12/2017 12:56 pm
jean-paul.b2
(@jean-paul-b2)
Thanks a lot !
Veröffentlicht : 29/12/2017 4:49 pm
Peter L
(@peter-l)
Also make sure the build plate is clean. Wipe it down with acetone right before printing--any time you touch the build surface it will leave some residue behind.
Veröffentlicht : 29/12/2017 7:02 pm
jean-paul.b2
(@jean-paul-b2)
Looks nice this time ! Thanks for your help guys 💡 😀
https://photos.app.goo.gl/5EGVRMaqkZJpbRKP2
Veröffentlicht : 30/12/2017 8:54 am
