Print shifting
todd.m
(@todd-m)
Print shifting
So i have calibrated and made sure both Z rods are even on both sides. When i print ut works up until a certain height and starts shirting, the print sticks very well to the bed and i am using the defaul normal profile in Slic3r. See attached pictures, i am at my wits end with this. I am using the prusa white PLA at 210 hotend and 50 bed, One thing i have noticed and i think this is the issue is my X axis carriage seems to almot get stuck very slightly or it feels like it is binding. If anyone can help i would gladly appreciate it because i am getting pretty disappointing and almost regret dropping 6004 on this printer. Also i am aware that 3D printing can be tricky but this has been going on for a few weeks and i have hit a brick wall. What makes this difficult is that i have an original Prusa I3 while other ones out there are clones and while having the almost same kind of setup i still can't find a solution.
https://www.flickr.com/photos/137033750@N07/23188267760/in/datetaken/
https://www.flickr.com/photos/137033750@N07/23375514042/in/datetaken/
Respondido : 03/12/2015 5:01 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Print shifting
Hi Todd
Firstly don't despair! I have both a clone and an Prusa i3 original. I can assure you that although the clone is good, the print quality of the i3 is significantly better.
If you think the X-Axis is binding somewhere, remove the belt and make sure the extruder moves left and right easily. If it does not, you will find a problem with the build; possibly the mounting of the bearings. If the bearings are not running smoothly, you may have to replace one or two of them, but this is unlikely.
When you ensure the X Axis is free-running, replace the belt and ensure that it is tight. You need to be able to play it like a guitar string, although I could not possibly advise you which note to try to achieve!
You also need to check that the drive gear on the motor is aligned on the X motor.
Also check the Y axis belt tightness and alignment at both ends.
Please do the above, re-check endstop positions and run a test print then let us know the outcome.
Peter
Respondido : 03/12/2015 9:30 am
PJR
 PJR
(@pjr)
Re: Print shifting
Todd
Looking at your third photo (the printer), I see that you have "sprung-loaded" the bed, rather than using the "original" instructions.
I wonder if this is allowing movement of the bed in the opposite direction to the extruder movement?
Any chance you could revert to the "original" configuration for testing before modding?
Peter
EDIT: Also, I see you have the feed rate set to 165%. Faster you print the more inaccuracies there will be. Have patience, young sir!
Respondido : 03/12/2015 12:33 pm
todd.m
(@todd-m)
Re: Print shifting
Thanks for the fast reply. I have gotten rid of the spring mount because it wasn'working and went back to the original config. I have been making sure that the flow rate is 100 and not to exceed 50mm for print speed i stick with about 40 on normal .2 quality. I will try the reccomended info you posted.
Respondido : 03/12/2015 1:38 pm
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Todd
Try what I have suggested and please report back. If you still don't have any luck, can I suggest that you contact PR and give them a link to this thread.
Best way to contact them initially is via the "Live Chat" on the shop site.
Peter
Respondido : 03/12/2015 1:56 pm
Josef Průša
(@josef-prusa)
Miembro Admin
Re: Print shifting
I bet you don't have the belt pulley tight enough on the rod.
Founder and owner / Majitel a zakladatel
Respondido : 03/12/2015 6:31 pm
todd.m
(@todd-m)
Re: Print shifting
PJR
Thank you so much, i had the X belt too tight causing it to skip affecting the X and Z axis. Now i just need to get better at leveing my bed. i did 2 prints and they came out good. Next question i don't like slic3r all that much can you recommend a different one that works with the Original Prus?
Respondido : 04/12/2015 6:22 am
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Todd
There are 2 slicers I use which work well for me: KISSlicer and Cura. However I use Cura V15.04.2 as I have issues with the later versions.
KISSlicer allows me better control and results in better quality print. Cura is very quick and easy to use, so I use this when I don't need precise prints.
Both are free, although KISSlicer does have a low-cost "PRO" version, which I have, but only for the purpose of supporting the developer and not because it is necessary.
KISS does require more knowledge to use properly, but I found it a great way to learn.
Regarding calibration. I do things a little differently, but if you get an approximate calibration, you can then use a raft to print on. Rafts are very useful; they help the part to stick to the bed and they are very tolerant towards not-quite-level beds.
Peter
Respondido : 04/12/2015 9:29 am
fl0PPsy
(@fl0ppsy)
Re: Print shifting
Would you mind sharing your Cura settings/profile?
I've tried setting Cura up using the settings from the version of Slic3r that comes with the Prusa drivers as a guide but I haven't got everything quite right and prints aren't great.
Respondido : 04/12/2015 9:43 am
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Markus
Below is my Cura INI file (Zipped). This is for printing PLA at layer height of 0.15 with first layer at 0.25 and no raft/support.
Please note that I do not expect results with Cura to be as good as with KISS, but generally they are acceptable.
Peter
Respondido : 04/12/2015 11:05 am
fl0PPsy
(@fl0ppsy)
Re: Print shifting
If you think Kisslicer is better then would you mind sharing your ini files for that also?
I'd like to check out the different slicers to get a feel for how each handles different jobs.
The more I read about slicer the more I'm starting to think that there is no one solution for all. Each slicer seems to work well in certain situations.
Respondido : 05/12/2015 1:13 am
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Markus
Sorry, I missed your message earlier.
I have attached my KISSlicer settings, including a thin wall calibration instruction. Please note that the settings will differ from printer to printer.
You really do need to play around with this slicer; there are so many things to change and what works for me may not work for you.
Have fun playing...
Peter
Respondido : 05/12/2015 9:58 pm
fl0PPsy
(@fl0ppsy)
Re: Print shifting
Well I tried the KISSlicer settings and went through the calibration process in the PDF file. Here's the result. I also tightened all the pulleys and the shift I was experiencing is definitely better.
Here's an example of a print I just did using 0.10 detail.
Respondido : 07/12/2015 11:00 am
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Markus
That looks OK, but not as good as I would expect.
As you have done the calibration, at least we know that the precise amount of filament is being extruded. I think Josef needs to have a look at your photo and make his suggestions.
Peter
Respondido : 07/12/2015 11:32 am
fl0PPsy
(@fl0ppsy)
Re: Print shifting
Yes I would love some feedback on the print in the picture to see what else needs to be adjusted.
One thing I plan on doing is taking the X axis apart again and tightening the belt a little more. It is fairly tight but it sounds more like a bass guitar string when you pull it and let go. the Y axis on the other hand sounds very much like a normal guitar string when pulled and let go. I'll make sure the X axis is just as tight.
Thanks for all the help so far Peter, its much appreciated.
Respondido : 08/12/2015 3:47 am
PJR
 PJR
(@pjr)
Re: Print shifting
Hi Markus
The belt not being quite tight enough can cause the banding.
Last evening, I found that my printer was feeding too much filament, which can have a similar effect.
Have a look at the attached document. You can amend the material "Flow Tweak" parameter within KISS and if this is required for all materials, change the Extruder Gain in Hardware/Extruder tab.
Peter
Respondido : 08/12/2015 8:44 am
Josef Průša
(@josef-prusa)
Miembro Admin
Re: Print shifting
Hi, PJR is kinda right.
The calibration cannot be 100%, the filaments are manufactured with 0.05+-mm tolerance and the drive gears are ever so slightly different from piece to piece.
You can try lower the flow a tiny bit in Slic3r. See attached screenshot where I set 98% of the ideal plastic volume 🙂
Respondido : 11/12/2015 5:47 pm
