Print issue curling depending model location
timactive
(@timactive)
First of all, it is my first message so i will present me in 2 sentence.
I am newbie 3d printer. I buy the mk2s kit for my company for realize easily small prototype with my team. Why Prusa, because we see many good thing of this Printer.
After 2 week, i understand 3d print is a new world with lot of new terms to understand, i very like it, it is technical we can do many improvement.
So but last week, i try to print https://www.thingiverse.com/thing:2719434 for my son, but big issue the driver cockpit keeps curling :
So i realize many test, i change PLA to M-ABS(neofile).
I change temperature(bed and noze), change speed, edit live Z and relaunch Z calibration without success., I try with slicr before and after i buy simplify3d but same issue.... And i see in comment other person who have mk2s have exactly same issue.
After i decidate to turn the model at 180degre, but now it is for the shovel :
Have you any advice, what have I done wrong?
Publié : 31/01/2018 3:06 pm
timactive
(@timactive)
Re: Print issue curling depending model location
Shovel issue after rotation :
Publié : 31/01/2018 3:09 pm
JeffJordan
(@jeffjordan)
Membre Moderator
if the filament doesn't stick at every location of the pei sheet in the same way, you've either your pei sheet not 100% clean (fingerprints are a real problem), your heatbed isn't exactly flat... or your printer thinks that the heatbed isn't flat.
have a look at the hyperfine bed levelling thread.
Publié : 31/01/2018 3:57 pm
timactive
(@timactive)
Thanks Jeff,
I use actually this product https://www.makershop.fr/accessoires/774-nettoyant-plateau-imprimante-3d-nanovia-500ml.html to clean the pei sheet, i do that quickly before print but sincerely no each time.
Thank you, i will read this and apply all advice, i hope i will can print this model.
I also print that https://www.thingiverse.com/thing:2742479/#made , for curling issue i have on left side.
Publié : 31/01/2018 4:30 pm
