Print is going in different places
kashyap.s
(@kashyap-s)
Hello
I have the Prusa i3 plus Kit that I received and finally got up and running. I have had some moderate success printing as this is my first printer that is to be expected. But all of a sudden the prints have started to come out terribly misaligned. The prints tend to veer off to the y axis motor for some reason. I hope that someone can help me solve this problem. I have made sure that everything is square, tight, and calibrated. What stuns me the most that this started for no apparent reason. I did not change any settings on the printer or in sli3er. looking at the print the, x axis motor seems to be doing OK as the distance is consistence but the y axis motor is the one that is all of a sudden giving me problems.
Opublikowany : 20/09/2015 5:16 am
Josef Průša
(@josef-prusa)
Member Admin
Re: Print is going in different places
Are the belt pulleys on the motor shafts tight enough? If not, they slip on the shaft and cuase misaligned layers. 💡
Founder and owner / Majitel a zakladatel
Opublikowany : 20/09/2015 12:15 pm
kashyap.s
(@kashyap-s)
Hello
Yes sir the belts are nice and tight as instructed in the online instructions, they do " ping".
Opublikowany : 20/09/2015 3:22 pm
kashyap.s
(@kashyap-s)
This is a link to the image of the cube that I printed : http://imgur.com/gallery/xqgKOXF/new
Opublikowany : 21/09/2015 2:26 am
Josef Průša
(@josef-prusa)
Member Admin
It's not about how tight is the belt, but if the pulley is secured on the motor shaft. There are two setscrews, please check them.
Opublikowany : 21/09/2015 3:31 pm
