Print doesn't start - New Build
I just finished building my kit and went through all the setup procedures. I run pre-heat (let it reach temp) and auto home then select a print to start from the SD card but nothing happens. The clock is counting up, I can go pause/resume but nothing starts moving to start the job, it just sit here counting time.
Any advise?
Opublikowany : 14/09/2015 7:51 am
Re: Print doesn't start - New Build
I think its problem with name of gcode file. You cant use diacritics and dots in filename as far as I know. Try some basic filename, for example test.gcode :).
Opublikowany : 14/09/2015 10:45 am
