Please Help!! Issues with first layer!
nikolas.i2
(@nikolas-i2)
Hi!
I recently built my Prusa I3MK2S and had a few successful prints. However after about 5 prints, an issue with the first layer began to start. Here are pictures: https://drive.google.com/file/d/0Bz2wWQCllXQqUnUzdXUyR3BSSUFxampUWEZqaTU5SHJGNzlv/view?usp=sharing
Thank you in advance!
Napsal : 02/09/2017 8:33 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: Please Help!! Issues with first layer!
to be honest, it's a little bit annoying that new users doesn't read before they post.
Napsal : 02/09/2017 12:45 pm
AJS
 AJS
(@ajs)
I think there is advice for this problem in the second post on this thread:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
If that does not help, please comment back here and we can see what we can figure out.
Napsal : 02/09/2017 5:31 pm
nikolas.i2
(@nikolas-i2)
Thanks for the help. Unfortunately i did not fix the issue even though I followed all the tips on the thread.
Thank again
Napsal : 02/09/2017 11:11 pm
AJS
 AJS
(@ajs)
Thank again
nikolas.i2,
Sadly, we can't read minds, nor can we see your issue across the distance. We can't tell what steps you took, and what steps you did not take, or if you did them correctly. We don't know what your setup looks like.
If you want us to help, and we are happy to help, you need to be our eyes and ears, and you need to tell us what - in detail - you tried. Pictures help.
Your original picture clearly was a poorly set Live Z adjustment. Jeff and I pointed you to threads that explain how to do an accurate Live Z adjustment. What did you do? How did those Live Z adjustments turn out? Pictures?
Napsal : 02/09/2017 11:23 pm
