PLA Finishing - Which method?
Hello to all!
Well, this argument is often discussed on the net, but cannot find a real good answer. I'm new with 3d printing, so my first model is printed! But needs to be finished.
On your experiences, which is the best method to finish smooth a PLA print?
I've read about:
Thanks all for sharing your experiences.
Simon
Re: PLA Finishing - Which method?
Spray filler/primer and car paint.
sands easier than PLA
Ok, so your aproach is to fill the lines instead to polish it?
Any hit for this approach?
Could be a good way as well!
Any suggestions/experiences with the methods I've listed?
Thanks,
Simon
I have used acetone on PLA, it makes the surface go nasty and discoloured, but as I was trying to de bond some magnets that were attached with superglue, I wasn't bothered about the plastic,
I have done a little sanding with wet and dry abrasive paper which is time consuming...
and I use a deburring tool to remove the first layer flange (Squish)
I have two of these, one has a plastic handle, cost about £1.35 from China. the other has an aluminium handle and came from England at about £5.45
I haven't tried the other methods
Thanks!
I think I'll try with "Ethyl acetate" meanwhile, in waiting for other experiences 😉
