PID Calibration
PaintX
(@paintx)
PID Calibration
How is the PID Calibration in the new Menu working?
i haven´t found any information to this topic?
just start the PID Calibration or did i have something to do?
thank you in advance
Postato : 17/08/2017 3:16 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: PID Calibration
I think I can remember that you need to set the temperature at which the calibration should occur.
anyhow, the implementation of the menu based calibration is a little bit sloppy, it's better to do it step by step, as it is described here.
Postato : 17/08/2017 3:32 pm
AJS
 AJS
(@ajs)
Re: PID Calibration
I have had good luck with the PID calibrations on the menu. They are fully automatic.
Postato : 17/08/2017 4:16 pm
PaintX
(@paintx)
Re: PID Calibration
so you mean just activate and wait to finish?
no filament loaded or preheat?
thank you
Postato : 17/08/2017 4:31 pm
AJS
 AJS
(@ajs)
Re: PID Calibration
That is my recollection. (I only did it once.)
Postato : 17/08/2017 5:07 pm
