Only blue light on LCD
I have problem with LCD display and controls on control panel....when I did the assembly of Prusa from kit, the content on lcd was OK, but the control button wasn't working (it works only push button and navigation didn't work). Than I have reloaded firmware (according to prusa instructions) and now there is nothing on display (only blue light)...do you have any idea where is the problem?
Re: Only blue light on LCD
I had only blue light at first but it was due to the cables from the LCD to the control board being backwards. Maybe check that?
Hi, try use FW 1.75mm RAMBo mini 1.0 http://www.prusa3d.cz/wp-content/uploads/FW_RAMBO_MINI_1_0_175_v1.zip
this FW help me sorted this problem with LCD.
David "REZI-st" ÅezáÄ
Senior Environment Artist & 3D/2D freelancer & Prusa i3 MK2S
Autodesk 3ds Max & Softimage XSI & slicer Simplify3D 4.0.0
