[Zamknięte] Odd Wave pattern on diagonals
nickexile
(@nickexile)
Hey there fell Prusa-ites,
Has any one run across this strange behavior before? I am getting ripples or waves on my diagonal lines.
I am using the MK2 btw.
I thought it might be the extrusion causing this, but temp changes and other settings have no effect, and it appears to follow a pattern.
Any ideas are welcome!
Thanks Chappies.
Opublikowany : 11/10/2016 3:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Odd Wave pattern on diagonals
Over-extrusion, possibly caused by nozzle being too low.
Peter
Opublikowany : 11/10/2016 3:21 pm
admi-11
(@admi-11)
RE: Odd Wave pattern on diagonals
Posted by: @nickexile
Thanks Chappies.
Hey, have you figured out the issue? I'm having almost identical issue on a fresh built MK3S
Opublikowany : 13/05/2020 12:03 am
