Nozzle wear
montreuilg
(@montreuilg)
Nozzle wear
Good morning everyone,
What are the signs of a worn nozzle? How do you know when to change it?
_
gabriel
Opublikowany : 26/12/2016 4:27 pm
david.b14
(@david-b14)
Re: Nozzle wear
If you are only printing PLA then it should not be an issue. If you switch to abrasive filaments like carbon fiber / metal it can destroy the brass nozzle after just one print.
Opublikowany : 26/12/2016 4:45 pm
montreuilg
(@montreuilg)
Re: Nozzle wear
The question remains... 😉 😎
Opublikowany : 26/12/2016 5:56 pm
simon.p
(@simon-p)
Re: Nozzle wear
Well, true but it does not answer any of the two questions in the post.
Opublikowany : 26/12/2016 6:05 pm
david.b14
(@david-b14)
Re: Nozzle wear
I have not had one wear out yet, but from what I read on the 3D groups you will not be able to print in fine detail. I think because the nozzle hole is an uniform circle.
Maybe a test is to print a single line circle? Was the first line uniform? If the nozzle wears out and the opening is no longer a circle, parts of the 1st layer would be fatter, but I am just guessing.
For example, once the nozzle is worn, I bet you would not be able to print this moving part:
http://www.thingiverse.com/thing:913675
Opublikowany : 26/12/2016 9:52 pm
montreuilg
(@montreuilg)
Re: Nozzle wear
Thanks David,
So you are saying precision will be lost, and I would tend to agree especially if the nozzle tip geometry is severely affected.
I found this document, with nice clear pictures of worn nozzles and explanations:
http://e3d-online.com/is-carbon-killing-your-nozzle
_
gabriel
Opublikowany : 27/12/2016 11:59 am
david.b14
(@david-b14)
Re: Nozzle wear
Thanks for the link, it was very informative and makes sense.
Opublikowany : 27/12/2016 5:47 pm
