Nozzle hits been at all points on Z calibration
I've just finished building my i3 MK2 and when I run the Z callibration, the nozzle crashes into the bed (quite substantially) on all nine points.
Anyone know what I've done wrong?
It seems like on the left side the max up is a few millimeters lower than the right? Is this causing the problem?
Thanks,
Phil
Re: Nozzle hits been at all points on Z calibration
💡 check the pinda probe. both height and electrical connection.
➡ height check: the tip of the pinda probe should be 0.7mm above the tip of the nozzle.
➡ electrical check: in a dark room, you should see some (dim) red light at the end of the pinda probe where the cable leaves the housing.... when you put some metal under the tip of the probe, the light should go off.
That fixed it. Just had to lower the probe a little. Thanks a million!
