Nozzle cant heat up more than 190 degrees C
nikolaj.k
(@nikolaj-k)
Hi Guys,
Today my beloved Prusa I3 Mk2 started acting up.
I cant get it to heat the extruder more than around 190 degrees, and it takes it around 15min to reach that temperature.
Could it be the heating element which is damaged? or is it the main control PCB?
Anybody experienced anything like this before?
Best regards
Nikolaj
Postato : 01/12/2016 12:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Nozzle cant heat up more than 190 degrees C
Check the extruder connector on the RAMBo.
Check the in-line thermistor connector if you have one.
Peter
Postato : 01/12/2016 11:13 pm
