Nozzle broken?
stephane.t
(@stephane-t)
Nozzle broken?
Hello,
I launched a print this night and this morning here is how I found the nozzle :
I removed the ABS sticked, but I think the head is broken :
What part do I have to change please?
I changed the ABS filament, and I notice the temperature was from 180 to 210 °C, and on the printer it was written 255 °C, is it the problem?
Thanks
Opublikowany : 16/08/2017 12:16 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Nozzle broken?
Heat break: http://shop.prusa3d.com/en/mk2-spare-parts/121-e3d-heatbreak.html
Peter
Opublikowany : 16/08/2017 12:21 pm
stephane.t
(@stephane-t)
Re: Nozzle broken?
The link is broken.. :
"There is 1 error
You do not have access to this product."
Opublikowany : 16/08/2017 12:23 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Nozzle broken?
the link works, but you need to be logged in at your prusa shop account (and maybe need to be granted access to the spare parts section by chatting with the prusa sales team).
actually the heat breaks are out of stock.
so what about this one ?
Opublikowany : 16/08/2017 12:30 pm
stephane.t
(@stephane-t)
Re: Nozzle broken?
Ok, you think this is just this part broken?
Opublikowany : 16/08/2017 1:06 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Nozzle broken?
Yes, it's always good to know how the things look inside (and how the parts interact with each other):
picture is from https://3dprinting.stackexchange.com/ .
Opublikowany : 16/08/2017 1:08 pm
stephane.t
(@stephane-t)
Re: Nozzle broken?
Ok, thanks.
For the problem itself, do you thing it is because the temperature is not the same with the new ABS filament?
Opublikowany : 16/08/2017 1:40 pm
PJR
 PJR
(@pjr)
Re: Nozzle broken?
You may also want to check the the thermistor and heater cables are intact as you may want to order those as well.
Peter
Opublikowany : 16/08/2017 1:45 pm
