Newbie having probs with First Layer Calibrartion
Hi All,
I'm new to 3D Printing and have built the MK3 and done the calibration tests and all ok except for the first layer, I have followed the instructions and tried the prusa logo from the SD card but 1. it leaves gaps between each line of PLA, 2. it gets to a certain height then the print moves and it all goes wrong.
Any help, pointers to get a newbie up and running would be much appreciated, hope to hear from someone 🙂
Rob
Re: Newbie having probs with First Layer Calibrartion
Poor adhesion + gaps in your layers sounds like you need to lower the extruder via Live Z adjust . Could mean under-extrusion if its not the Live Z. Maybe post pictures of your troubled prints for the sharp-eyed vets to diagnose.
this forum is a good source of information for newbies.
just take your time and read a lot of the (large) threads here.
for example this one 😎
I'm also new and am currently working out similar issues as you.
the thread jeff posted has been good so far, i'm on about page 6, working my way through it
this one is also a good read: https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/hyperfine-bed-leveling--t4330.html
i'm hoping to try out the hyperfine bed leveling soon!
There are lots of good things on this forum. Here is another for beginners:
