New slic3r prusa edition and first layer
cyrille.p
(@cyrille-p)
I'm using the last slic3r prusa edition 1.31.6
I've noticed that compared to the previous version,the first layer is now 0.2mm (it was 0.15mm before).
So I adjusted my live Z adjust according to this new value (I'm using my own square calibration gcode). When I slice my own STL files, they are all sliced with 0.2mm value for this first layer. Everything prints correctly.
But I also want to be able to print the Gcodes files from prusa, and the problem is that when I look at the Gcode provided with the drivers 1.7.5, the first layer is still 0.15mm. Even the V2 calibration is configured with 0.15mm. So I think if I try to print those Gcodes, there will be a bad first layer (it's a 50micron gap)?
Am I missing something or should I readjust live Z adjust each time I'm printing my own files or prusa files ?
Thanks for your help. I know Peter is an expert in Gcode and could probably advise me.
My youtube channel about the Prusa I3 MK2 https://www.youtube.com/channel/UCz-zQZcKcvEDdd9C9hOKYWg
Respondido : 06/12/2016 7:20 am
henning
(@henning)
Re: New slic3r prusa edition and first layer
I wonder if i got something wrong here.
I thought that, when i home the z-axis with live Z adjust, my nozzle should be right on the bed. In that case, the first layer height is independed from the live z adjust. When i move my z-axis to 0.15mm it should be at 0.15mm with live z-adjust and without it is at 0.15mm-(live z adjust).
For example i have a live z adjust = -0.300mm. It is at 0.45mm.
So when my first layer height is 0.2mm and z-height is adjusted, it should be at 0.2mm.
Do i miss something?
Respondido : 06/12/2016 9:45 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Cyrille
You should not need to make any printer adjustments when printing with a different first layer height. The slicer will simply instruct more filament to be extruded to take into account any difference.
More material extruded on first layer gives a better stick, so I guess that's why PR have made the change.
Peter
Respondido : 06/12/2016 10:29 am
cyrille.p
(@cyrille-p)
Thank you henning and Peter for your answers.
Henning I think you are right, that's the way to understand it. Otherwise, it becomes very difficult to calibrate Z for each gcode and each 1st layer.
Peter, thank you also for your answer, it seems logical.
Respondido : 06/12/2016 12:34 pm
