New assembled Printer,first printed parts
daniele.e
(@daniele-e)
Hi guys,
i have just finished to assembly and calibrate my Prusa (exceptional kit,perfect instruction and easy of use).
I try to print Marvin (0.1 resolution),the Benchy boat and a personnel project.
Now if i can ask i have 2 little "problem" 😀
The first,on the boat,as you see in the photo i have the boat base warping up (i use PLA heat preset of the printer),how can i fix it ?
Second,over the Marvin's own left eye,i don't have a clear line (instead at right i have a clear line),do you have some advice for it?
The third,i think i have reach a good surface finish in my own project.
Thank you very much
Daniele
From Florence with Rage!!!!!
Postato : 22/12/2016 12:24 pm
Ancientwolf
(@ancientwolf)
Re: New assembled Printer,first printed parts
The marvin looks like a high layer height. Did you just print it from the SD card?
As for the benchy, using default bed temps? Try 210/205c hotend and 60/55c for first layers respectively. Clean your bed with 91% alcohol too between prints.
Yeah, its that guy... 3D Nexus
Postato : 24/12/2016 5:22 am
daniele.e
(@daniele-e)
Hi!
the marvin come's out directly from the SD,today i have download the 3dhub file,i will slice it and try to print at 0.05 .....
For the boat i try to higher the bed temp of 5 degrees,now it is perfectly planar,thank you very much.
Postato : 30/12/2016 12:40 am
