New 1.75mm extruder housing printed part files
derek.s
(@derek-s)
Does anyone have the stl files for the new 1.75mm extruder holder? My parts that came with my kit were a little warped so I super glued the parts together after assembly to close the gaps. I wanted to try to re-print them.
Thanks,
Derek
Respondido : 03/09/2015 9:53 am
Josef Průša
(@josef-prusa)
Miembro Admin
Re: New 1.75mm extruder housing printed part files
Hi, I will be uploading them on the web today.
If my staff sent a warped part and they broke, I will ship you new parts. You should have contacted my support right away, so I could slap them when it happened. Since this week I implemented another QC check, and every bag will have the picker number on it, so I can find out who exactly forgot to pack a part or packed a not 100% part :-/
Founder and owner / Majitel a zakladatel
Respondido : 04/09/2015 12:15 pm
derek.s
(@derek-s)
Your staff got back to me and I received the stl files. To complete the assembly, I used superglue and clamped the holder halves until the glue set. It's been working well, I just won't be able to take the holder apart if I ever need to without cracking it.
Thanks. I appreciate your reply. So far the printer is working pretty good. I'm learning the printer such as tall thin objects are subject to layer separation. I can't have a breeze blowing through my living room or the heat bed never heats to more than 98-99 deg. I'm now trying to solve print bed adhesion to that I can print lego type blocks (so far the first layer keeps lifting) and bridging so the underside layer isn't stringy and separated.
Thanks again.
Derek
Respondido : 06/09/2015 9:35 am
Josef Průša
(@josef-prusa)
Miembro Admin
Try PLA for lego blocks 🙂 They will be nice and sharp with new cooling system 🙂
Respondido : 11/09/2015 3:00 pm
