Re: My poor adalinda
yeah, very unlucky... so close before finalisation.
looking at the feet of the print: you didn't use the *.gcode that came with the printer, so you sliced it yourself.
what's the height with which adalinda should be printed ? remember: there's a limit of 200mm given for the i3 mk2 (even so approx. 208mm should be reached, depending on the build).
It was 150mm in height..
Apparently my smooth rods were getting stuck. I use IGUS bearings. I lubricated the smooth rods using some high speed bearing silicone oil and now the axis'es slide perfectly. Will attempt the same print once I feel confident enough. 🙂
can you slice at 150mm print the remainder and glue together?
sand, prime and paint!
regards Joan...
