My poor adalinda
murloc992
(@murloc992)
My poor adalinda
Hello,
I was wondering if somebody knows what could cause shifting like this?
Once I noticed this happening on the same model on the second/third layer, it just shifted identically..
There also are underextrusion marks.. Need a new spool holder..
Respondido : 29/04/2017 8:46 am
JeffJordan
(@jeffjordan)
Miembro Moderator
Re: My poor adalinda
yeah, very unlucky... so close before finalisation.
looking at the feet of the print: you didn't use the *.gcode that came with the printer, so you sliced it yourself.
what's the height with which adalinda should be printed ? remember: there's a limit of 200mm given for the i3 mk2 (even so approx. 208mm should be reached, depending on the build).
Respondido : 29/04/2017 3:27 pm
murloc992
(@murloc992)
It was 150mm in height..
Respondido : 29/04/2017 6:44 pm
murloc992
(@murloc992)
Apparently my smooth rods were getting stuck. I use IGUS bearings. I lubricated the smooth rods using some high speed bearing silicone oil and now the axis'es slide perfectly. Will attempt the same print once I feel confident enough. 🙂
Respondido : 30/04/2017 1:31 pm
can you slice at 150mm print the remainder and glue together?
sand, prime and paint!
regards Joan...
Respondido : 30/04/2017 6:25 pm
