mk2 upgrade
gordon d..l
(@gordon-d-l)
mk2 upgrade
Upgraded to new Prusa mk2.
now hear ticking from power supply.
No Lcd screen
Z axis goes below 0 limit
Help
Postato : 02/07/2016 9:02 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: mk2 upgrade
PSU making a ticking noise would tend to indicate that it is being overloaded.
Unplug the PSU connections from the RAMBo, turn on the power and see if the ticking persists.
Peter
Postato : 02/07/2016 9:24 pm
andersonta
(@andersonta)
Re: mk2 upgrade
Also check to see if the right AC voltage has been selected on the PSU.
Postato : 03/07/2016 7:39 am
PJR
 PJR
(@pjr)
Re: mk2 upgrade
I thought about that also, but as Gordon has upgraded from a Mk1, I doubt very much that he has changed the voltage setting during the upgrade process.
More likely that the 12V cables from the PSU have been damaged by an over-tight cable tie or been plugged into the wrong connectors on the RAMBo.
Peter
Postato : 03/07/2016 8:46 am
