mk2 -> mk2s upgrade - pinda nut removal problem
prusayo
(@prusayo)
I'm at the disassembly stage:
Step 8 Extruder disassembly (Part 1)
"Use pliers to release the nut holding P.I.N.D.A. sensor. Proceed carefully since this nut is glued!"
I used blue loctite. I don't see how it's possible to remove the nut since the probe rotates when I attempt to rotate nut. I tried using a razor to remove the loctite, what else can I do?
Posted : 26/05/2017 10:15 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: mk2 -> mk2s upgrade - pinda nut removal problem
You have my sympathy...
I have not glued any part unnecessarily, so I didn't suffer this issue. The only thing I can suggest to to hold the probe body with pliers and hope that the probe survives.
Peter
Posted : 26/05/2017 10:51 pm
Nigel
(@nigel)
Blue Loctite should be easily removed mechanically as said on many websites. You just need the right tools. A top and bottom spanner didn't work for me with my Blue Loctited Pinda probe nuts. Try using a heatgun. It worked for me. I borrowed the heatgun from my wife. She does crafts and I use it mostly for heatshrink. Its a gentle heatgun.
Nigel
Posted : 27/05/2017 2:14 am
corey.a
(@corey-a)
And once you get it off, grind down a flat washer on one side and add that and a lock washer under the nut. Screw that loctite!
Posted : 27/05/2017 4:53 am
prusayo
(@prusayo)
Peter
That's what I ended up doing, thread got partially dented. Hopefully it should still screw in. Thanks.
Posted : 27/05/2017 6:44 am
prusayo
(@prusayo)
Interesting, didn't realize that would work.
Posted : 27/05/2017 6:45 am
Nigel
(@nigel)
Update protect the Pinda probe rubber end with aluminium foil if using a heat gun to free the Pinda Probe. Most Loctite secured mechanical parts can be freed by using heat. Red, Blue and whatever.
Nigel
Posted : 28/05/2017 4:56 am
