MK2 Build
tom.r
(@tom-r)
MK2 Build
I had bought the original printer and after about a week the MK2 upgrade became available. I now have the upgrade. Have not built the first one yet. Going to start assembling it and would like to know should I use the MK2 manual from the beginning. Thanks. Tom
Opublikowany : 04/07/2016 1:18 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MK2 Build
Tom
As the upgrade requires a complete teardown of the Mk1, I think it best if you assume that you have done that and use the upgrade manual.
There are some areas that will be slightly different between the MK2 Upgrade and New Build.
Peter
Opublikowany : 04/07/2016 1:21 pm
