Measuring the layer height in high resolution mode
I used the gcode file in the sdcard to print the Frog in high resolution (0.05mm or 50um). To check the accuracy achieved by Prusa i3 MK2S I got some photos in my optical microscope and estimate the layer height. I measured the total height of the frog's nail with a caliper and used the ImageJ software to estimate the distance between the layers (distance between the peaks in the profile of gray levels in the image). The measured layer height was 49.4um or 0.0496mm. Congratulations, Prusa Research! The results are in the attachments.
Thanks,
Khyale.
Opublikowany : 28/10/2017 3:32 am
