Left side of bed not leveled issue
tiago.d
(@tiago-d)
I've been repeating all the calibration steps over and over as stated in the following post:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
My calibration test square shows that the left side of my bed may be off slightly.
I didnt build the printer, received it already assembled so my knowledge of the working and build sides of things isnt great.
What is the best way to fix this issue so i dont get the bellow errors?
I've cleaned the bed with Windex and IPA 99% and have even used a glue stick. If I adjust Live Z then the right side will be too close and dig into the layers.
Postato : 30/09/2017 4:44 pm
AJS
 AJS
(@ajs)
Re: Left side of bed not leveled issue
You may need to adjust the printer to level it.
Step 15 here:
http://manual.prusa3d.com/Guide/4.+Z-axis+assembly/296
Make sure the Y-axis if fully seated in the frame. And see if that now makes it level.
Postato : 30/09/2017 5:33 pm
