LCD would no long come on
tut.t
(@tut-t)
Hi all, I currently own a Prusa I3 1.75mm. I finished assembling the kit and decided to followed the steps in the instruction to calibrate the printer. I turned the printer on and everything was fine, the temperatures are both at 30C. I chose the preheat option and selected PLA. Then, I think I saw a flash and the LCD went black. Now, I cannot get the LCD/ the printer to come back on. Please help, I really have no idea where to go from here. Thanks
Napsal : 14/09/2017 2:17 pm
henrik.w
(@henrik-w)
Re: LCD would no long come on
Hello Tut!
Have you looked in the Rambo box and see if the lcd cables are firmly attached to the board?
/Henrik
Napsal : 14/09/2017 5:27 pm
tut.t
(@tut-t)
Dear Mr.Henrik,
I tried unplugging it and plugging it in again to make sure it's not loose. I also looked at the fuse to make sure they are not blown out. Do you have any other idea as to why? As I stated, I think I might have blown/ short something after I initiate the preheat command.
Thanks,
Tut
Napsal : 15/09/2017 11:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
There are 2 5 Amp fuses on the controller board and 1 15 Amp fuse.
One of the 5 Amp fuses is used for the electronics, but you cannot always tell if it has blown by just looking at it. Use a continuity tester is you have one to check all the fuses on the board.
There is also a fuse on the power supply housed within the mains power socket. Also check that fuse.
There is a remote possibility that you have a faulty PSU, but all this would be a lot easier to check is you have access to a multi-meter.
Peter
Napsal : 15/09/2017 11:50 am
JeffJordan
(@jeffjordan)
Member Moderator
a shortage at the +5V, maybe due to a defective or wrong attached y- or x- endswitch may cause the same.
standard procedure to find such problems:
unplug every device from the rambo board, except the power supply.
does the onboard leds show any activity ? does the printer respond when you connect them through USB to your PC (use pronterface to monitor any response, connect with 115200 bit/s) ?
if so, proceed with plugging in the lcd connectors and proceed with the other devices (endstops, p.i.n.d.a., heatbed, hotend, thermistors, steppers etc.).
Napsal : 15/09/2017 1:40 pm
