LCD - no Clear() Method? LCD messy
thilo.n
(@thilo-n)
Hey 😀 ,
yesterday i assembled my MK2 updated the Firmware and calibrated it. I'm so super-happy to print gorgeous things now.
Printing works quite good. Seems like i have to put some more time in adjusting Z but a rather annoying problem i'm facing right now is my messy LCD.
Whenever i e.g. execute the XYZ-calibration the info text on the LCD is not cleared before the next page is written. So i have every character from the last pages, that was not overwritten by the actual page, on the actual page making the LCD very hard to read. 😕
I'll upload a picture with the issue as soon as my printer is ready with the current print to clarify what i mean.
Did anyone experiencing the same problem? Is it a bug in the current firmware or did the flashing of the new firmware go wrong?
Greetings
Edit: It's not everywhere. Seems like that mainly the onboard-applications are affected. Getting into the menu and back to the info screen e.g. works fine.
Publié : 03/03/2017 11:06 pm
thilo.n
(@thilo-n)
Re: LCD - no Clear() Method? LCD messy
Here is the promised picture. I'm moving the z-axis in this picture. But the letters from the top menu, wich were not replaced by new ones persist.
This happens only if an onboard programm like calibration is executed.
Publié : 04/03/2017 11:41 pm
JeffJordan
(@jeffjordan)
Membre Moderator
😕 might be that one of the ribbon cables has a wire with bad contact. check out if something changes when you swap the cables at both sides (lcd and rambo).
➡ if the problem still persists, check if all the pins from the lcd display itself are properly soldered at the lcd-2004 module.
Publié : 05/03/2017 1:26 am
thilo.n
(@thilo-n)
The problem persists after changing the cables. I'm going to look at the lcd unit now.
Thanks for the advise and your time! 😉
Publié : 05/03/2017 10:53 am
