LCD doesn´t power on
BLACKY
(@blacky)
Hey.
I just finished building the I3 and wanted to start it, but the LCD doesn´t power on. It makes a few "beep" noises sometimes but the screen is off. I checked all the cables and cannot find any wiring mistake. The RAMBo LEDs are green. When I plug the USB into my computer to install the firmare also the firmware updater doesn´t recognize the printer just showing me COM4. Though the printer shows a yellow LED when plugged into the computer. What can I do?
Postato : 29/01/2016 4:08 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: LCD doesn´t power on
Hi Nils
The usual cause of this is incorrectly oriented insertion of the ribbon cable connectors on the RAMBo board.
Could you please possibly post photos of your ribbon cable connectors at both ends (where they attach to the RAMBo and the LCD boards).
Thanks
Peter
Postato : 29/01/2016 4:53 pm
BLACKY
(@blacky)
Hey Peter
So this is what it looks like, with a mac I was able to update the firmware but the LCD still doesn´t power on. Hope the pictures are ok.
Thanks for helping
Postato : 29/01/2016 5:13 pm
PJR
 PJR
(@pjr)
Yeah, on the RAMBo the locating lugs on the connectors should be towards the middle of the board. See this picture: https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/UjFyyGJRAG4SipZ5
On the PC you need to load the correct drivers - drivers download here: http://www.prusa3d.com/drivers/
Peter
Postato : 29/01/2016 5:33 pm
BLACKY
(@blacky)
Jes, it finally works!
Thanks a lot for helping and have a nice day! 🙂
Postato : 29/01/2016 5:35 pm
zach.c
(@zach-c)
I'm having the same problem and swap the lcd cables and still nothing is moving and LCd is not displaying anything.
I hope somebody can point out to me I'm doing anything wrong :p
Postato : 05/04/2016 10:00 pm
zach.c
(@zach-c)
The only thing it can do now is it beeps loudly if I press the knob and it back light lit up , and stop beeping when I turn the knob. LCD or Rambo is dead on arrival?
Postato : 05/04/2016 10:03 pm
PJR
 PJR
(@pjr)
Zach
The connectors on the rambo - they should have the locating lugs pointing towards the centre of the board.
Peter
Postato : 05/04/2016 10:05 pm
PJR
 PJR
(@pjr)
Zach
Just found the picture: https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/UjFyyGJRAG4SipZ5
Peter
Postato : 05/04/2016 10:42 pm
zach.c
(@zach-c)
Thanks Peter !!! You have saved me from my 1 day frustration of the not working electronics.
I think the manual should highlight the connector it in the picture 🙂 ..... The printer is alive !!! Yes !!!
Now calibration problems begin. I'll put my problem in the calibration section.
Postato : 06/04/2016 6:54 am
PJR
 PJR
(@pjr)
Zach
The photo I posted was from the manual (albeit the online version).
Peter
Postato : 06/04/2016 9:47 am
