Layer shift after power panic (b150)
Tried power panic recovery a couple times now and each time I get a ~1mm shift in Y. I've looked at the Y axis and can't see any obstructions. The linear bearings are the first thing to hit the frame on either end. This is an I3 MK3 running b150 firmware. Printing from SD card.
Bryan
Napsal : 27/01/2018 8:34 pm
Re: Layer shift after power panic (b150)
I too have had a layer shift after power panic. Happened after each power panic, I have had 2. I see no obstruction. I have run through the calibration wizard 3 times. My build is perpendicular. Firmware is 3.1.1-RC5-150. Also printing from SD card.
Napsal : 14/02/2018 8:44 pm
Is there a solution for this?
Napsal : 01/09/2018 7:49 am
