Is the speed faster when using the SD card?
david.b14
(@david-b14)
Hello,
I setup my printer to print really fast using the 80mm/s profile as described here:
- http://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/speed-from-40mm-s-to-80-safe-on-mk2--t3388.html
I recently needed to do color prints which needs to be done from the SD card since OctoPrint can time out if the color change is not done fast.
It seems like the print is faster when done from the SD card. Is this because there is a baud rate limit that is being hit when printing from OctoPrint?
Publié : 05/03/2017 11:17 pm
