Initial 9 point Calibration Fails (Wizard)
aograin
(@aograin)
Hello,
I've searched the forum but haven't found a similar issue. I just finished assembling my Prusa MK3 kit and when running the calibration wizard I'm having an issue after it calibrates the first 4 points and wants to move on to the 9 point calibration with the steel sheet attached. It just smashes straight down into the bed.
XYZ Length Test: PASS
Hotend and Fans: PASS
4 Point Calibration (without steel sheet) : PASS
9 Point Calibration (with steel sheet): FAIL
My pinda probe was initially set at the recommended height of a zip tie. I have since even lowered it a bit further using a few sheets of paper as a guide. So the probe should be more than ok. I have also verified that the probe sensor works correctly using the steel sheet (light turns off when it gets close).
The final odd thing is that if I manually run the 9 point calibration from the menu it seems to work fine...
Running the latest firmware 3.1.1 (Feb 5th)
Publié : 25/02/2018 5:46 pm
aograin
(@aograin)
Re: Initial 9 point Calibration Fails (Wizard)
Not sure if this is bad, but to anyone else running into this issue I was able to resolve it by running the calibrations manually in the calibration menu. The only thing I lose out on is determining how straight my bed is.
Publié : 25/02/2018 7:23 pm
