Inexplicable X-axis belt twisting
peter.p13
(@peter-p13)
I have observed that X-axis belt on my (kit) Prusa i3 MK2S is twisting depending on which way it is moving. The movement seems to originate in pulley on the other side of X motor, but I have no idea why. The pulley itself just rotates and does not wiggle. The belt itself is tight and there is no twisting motion on the left (motor) side.
I captured a video of this: https://gfycat.com/gifs/detail/FailingWatchfulBellsnake
Some other photos: https://imgur.com/gallery/8RjQQ
It is very possible that I assembled something wrong, but I cannot think of what that might be.
My questions are:
1. Should I be worried about this? (Perhaps it is normal and does not affect printing)
2. What initiates the belt twisting?
3. How can I fix it?
Thank you for any info.
Respondido : 17/09/2017 10:15 pm
AJS
 AJS
(@ajs)
Re: Inexplicable X-axis belt twisting
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/belt-rubbing-on-x-axis-t1232.html
Respondido : 17/09/2017 10:53 pm
peter.p13
(@peter-p13)
Thanks, it does seem that the belt is touching the pulley sides, I'll try to center it somehow.
Respondido : 18/09/2017 9:17 am
harryg
(@harryg)
I have modified the x-carriage on my MK2S to allow belt adjustment for the rubbing issue.
I raised the parts that hold the belt by 4mm.
Here is the link: https://www.thingiverse.com/thing:2541730
Respondido : 19/09/2017 1:41 am
Iancun
(@iancun)
I have the exact same problem - the printer prints fine, but I get the belt twisting at the idler side. It doesn't appear to be rubbing in the place that the updated model shows, could there be another cause for this?
Respondido : 26/09/2017 4:20 pm
henrik.w
(@henrik-w)
Could it be that the belt is ever so slightly misaligned when watching a straight line from the one side of the belt (x-stepper motor) to the other side (x-idler) compared to where the ends of the gt2 belt is anchored - see picture?
The forces (F) pulling the belt will then probably be slightly in a cross formation instead of a optimal straight line and thus the belt will be twisting.
/Henrik
Respondido : 27/09/2017 2:52 pm
pandionx
(@pandionx)
I found this on the Mk3 forum - pretty sure it is the same issue:
https://github.com/prusa3d/Original-Prusa-i3/issues/50 .
There is a fix for it in the link as well.
Respondido : 06/02/2018 7:06 pm
