I3mk3 x-axis selftest problem
8orge
(@8orge)
Hi .
Im having a big problem with the x-axis selftest .
I have checked that the printhead can move freely from side to side and
that nothing is sticking out and hitting the frame .
Still it says there is an lenght error . The printhead do make an
odd glimpse of a jump/hold when moving to the right side like it is skipping
a teeth on the belt ,the belt i however perfekt (not too tight and not too loose).
Just a side note ,this is not the first diy printer i have built ,so i have checked
several other things .
Please i hope somebody can help me with this odd problem .
Regards
Kim.
Opublikowany : 17/02/2018 2:02 pm
8orge
(@8orge)
Re: I3mk3 x-axis selftest problem
Just solved the problem .....the belt needed just a tiny amount more tightness ....just a teeth more that
was the solution ....it is very sensitive 🙂
Rest of the selftest performed without any problems 😀
Regards
kim
Opublikowany : 17/02/2018 2:20 pm
