I need help with the Bed Configuration
rainer.d
(@rainer-d)
Hi I´m Rainer and a Newcomer with 3D Printing
I have a Prusa i3 MK2 kit
the build up was easy and the manual perfect.
I have some Problem
If I print parts that goes over 105 to 205 on the Bed than it will not Print fine the Distance is to high in the area from 0,0 to 105 exelent
my Z axis is -0.720 perfect for the Front but the rear purt is schi.....t.
what can I do to setup the Bed perfect
thanks for your Help
R.
Napsal : 27/02/2017 7:15 pm
christophe.p
(@christophe-p)
Member Moderator
Re: I need help with the Bed Configuration
Hi and welcome aboard 🙂
If the diffeence is not too important, you may adjust the rear and front by sing the bed correction (not sure the exact label) in the calibration menu of your printer.
If it's not enough, maybe a double check of your build should be done.
Did you follow the full workflow for calibration ? (XYZ calibration, V2calibration print ... ) ?
I'm like Jon Snow, I know nothing.
Napsal : 28/02/2017 1:03 pm
