How to glue teflon to aluminium?
john.c26
(@john-c26)
Hi, I was able to remove plastic melt from the teflon tube of my extruder by a hot air gun; but it melted off the glue holding the tube to the metal of the extruder. Does anyone know what glue to use to reattach it?
Many Thanks,
John
Napsal : 22/11/2017 3:14 am
Cipis
(@cipis)
Re: How to glue teflon to aluminium?
I dont know which printer do you have (MK1/MK2), but there is no glue used on PTFE tube (or anywhere else). PTFE tube is secured by black collet on top of the hotend (PUSH=UNLOCK).
Look at assembly instructions (E3D on-line):
MK2:
https://wiki.e3d-online.com/E3D-v6_Assembly
MK1 (heatblock is upside down for MK1):
https://wiki.e3d-online.com/E3D-Lite6_Assembly
Napsal : 22/11/2017 7:31 am
JeffJordan
(@jeffjordan)
Member Moderator
beside the point that the ptfe tube isn't glued inside the aluminium body of the hotend (but hold by the little collet):
glueing teflon would be a real challenge, because the main property of the material is that nothing should stick at it. :mrgreen:
Napsal : 22/11/2017 4:17 pm
john.c26
(@john-c26)
Its tough to answer questions on this forum isn't it? With all the changes to the models....anyway the photo shown in the 1st reply was unfamiliar to me; my 3d printer extruder (MK2) doesnt have a 'collet', only a wisp of plastic around the teflon tube where it attaches to the metal part of the extruder. As for gluing teflon....of course I read about it and there are adhesives that are supposed to glue teflon to metal. Thanks for the replies.
Regards,
John
Napsal : 23/11/2017 2:27 pm
