Holes in print
mitch.m
(@mitch-m)
Holes in print
So I printed the frog but I got all these weird holes in him, is a calibration issue?
Postato : 02/02/2017 8:30 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Holes in print
sometimes had the same here with the frog at 50µm resolution.
depends on the filament, the flow rate and the temperature.
normally the advice would be to increase the number of top layers and the amount of infill... but that'll cause other problems at this high resolution.
guess when you print the frog in 200µm resolution, everything will be fine.
by the way, there is a good site that deals with a lot of different printing problems (hope i'm allowed to post this link here...).
Postato : 02/02/2017 10:36 pm
