High thin tubes printing problem
stephane.t
(@stephane-t)
Hello,
I have some issue printing high (7cm) thin tubes (4mm diameter) : All is very well printing until a few cm high. Then the tube is moving with the extruder and of course print quality is decreasing. is there any advice to maintain tubes?
Thanks
Napsal : 22/08/2017 4:04 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: High thin tubes printing problem
Large brim
Peter
Napsal : 22/08/2017 4:46 pm
JeffJordan
(@jeffjordan)
Member Moderator
Hello,
Thanks
by the way: it's a very challenging idea to print such a tall but thin part.
only way to try this is using a big brim at the bottom and reducing the print speed significantly as you gain height.
Napsal : 22/08/2017 4:56 pm
PJR
 PJR
(@pjr)
Maybe even a fillet on the brim.
{It's available in KISS 😉 }
Peter
Napsal : 22/08/2017 5:30 pm
stephane.t
(@stephane-t)
I have a 8mm brim but it doesn't have any effect because the problem is on the top, the bottom doesn't move! All the material is bending without moving the bottom... Ok, I will try to make thin parts connected to each tube to make them stick together, perh'ap's it will decrease movements...
Thanks for answer 😉
Napsal : 23/08/2017 11:24 am
