Help Removing Filament
dustin.h2
(@dustin-h2)
I built the kit just last week. Was printing great for a couple of days, then the filament got stuck. I just took off the nozzle and have it soaking in acetone and will clean it. But the filament is still stuck in the unit. Unload/load does nothing. I tried gently pulling it out, but it moved a bit and nothing more.
What is the best way to get the filament out?
Here is what I have: Filament is stuck in the silver heating unit and heating the PLA to 250 and load/unload do not work. The extruder gear can move it.
http://imgur.com/T9V1Ncd
Posted : 03/08/2017 11:07 pm
AJS
 AJS
(@ajs)
Re: Help Removing Filament
BE VERY CAREFUL WHEN WORKING WITH A HOT EXTRUDER.
Try heating it to 220, removing the nozzle, and gently and CAREFULLY push a small allen key up from the bottom (use pliers). That will usually clear it. Please don't burn yourself.
Posted : 04/08/2017 3:24 am
dustin.h2
(@dustin-h2)
Thanks for the reply. I just tried this. With the nozzle off - there is something blocking the heating block about 23mm from the bottom. That is as far as the allen key goes. I can't pull the filament out the top and it will not push through. Still jammed. Not sure the best path to take. Take it all apart and use acetone and a heat touch?
Posted : 04/08/2017 7:30 pm
