Help!!: First Print with ABS, I don't know what this problem is called
russelb
(@russelb)
Hi!
First time 3d printing with ABS
Please see attached picture.
I don't know what this problem is called.
The exterior surface is rough only in the top parts of the print.
How can I solve this problem??
Thanks
Posted : 02/12/2017 4:01 pm
David
(@david-37)
Re: Help!!: First Print with ABS, I don't know what this problem is called
I'm having issues as well. Hopefully someone will chime in and help us!
Posted : 02/12/2017 8:00 pm
AJS
 AJS
(@ajs)
I don't print ABS, but I think you have your cooling fan on - I think it should not be for ABS - which is causing it to cool too quickly and contract making that rough surface.
Again, I am not an ABS person, so maybe someone else can tell you for sure.
Posted : 03/12/2017 1:40 am
