Heatbed not working
joshua.q
(@joshua-q)
Heatbed not working
Hello, I'm currently using the old Prusa i3 MK1 not the MK2, its been good to me for 4 months and suddenly my heat bed isn't rising in temperature despite preheating up with the settings ,constantly at 25 to 35+ degrees, there's no light indicating it's heating. I have resort to lowering the heatbed temp in order to start my print. I'm not too bothered by it much since I'm printing with only PLA. I wonder is it due to firmware issue or it's the heatbed itself is the problem.
Napsal : 22/06/2016 8:06 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Heatbed not working
Hi Joshua
This is more than likely either a connector, cable or fuse issue, all of which can be checked out with a cheap digital multimeter.
Peter
Napsal : 22/06/2016 10:00 am
