Heatbed connector
kimmo.h
(@kimmo-h)
Heatbed connector
Hello!!
I need some spare heatbed connectors, i know that i can find them here in the prusa shop but i dont want to pay shipping for one
connector so i found these on ebay instead
http://www.ebay.com/itm/10Pcs-5-08mm-Right-Angle-2-Pin-Screw-Terminal-Block-Pluggable-Plug-Connector-/182233045192?epid=870527761&hash=item2a6def98c8:g:bWsAAOSw3xJXpZdt
But not sure they can stand the current being delivered to the heatbed, they have the following rating, Rated voltage:300V (250V)
Rated current:15A (10A) and further down in the specs they also write Rated Current: 5Amp so im a little confused!
what do you guys think?
//Kimmo
Postato : 03/08/2017 8:34 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Heatbed connector
It also says: Item location: ShenZhen, Guangdong, China
Barge pole...
Peter
P.S. You could try these: https://ultimachine.com/collections/electronics/products/pluggable-terminal-block-2-contacts-5-08mm-black
Postato : 03/08/2017 9:02 pm
kimmo.h
(@kimmo-h)
Barge pole...
Peter
Hi Peter! I was also looking for these on ultimachines page but they want $12.83 for shipping, so if these Chinese parts are not good enough i probably have to wait and buy these in the Prusa shop when i need some more parts..
Postato : 03/08/2017 9:33 pm
PJR
 PJR
(@pjr)
There's 2 things you could do:
1. Solder the cables to the underside of the board (best option)
2. These are apparently molex, so if you can find the part number, you may find them elsewhere: http://www.molex.com/molex/products/family?channel=products&chanName=family&key=eurostyle_terminal_blocks
Peter
Postato : 03/08/2017 11:26 pm
kimmo.h
(@kimmo-h)
Hi
Yes Peter they are called Molex 3953 and i dont want to solder the heatbed to the board because i like to remove the
bed when changing PEI, i will do some more research and try to find them here in sweden.
Thx Peter
//Kimmo
Postato : 03/08/2017 11:39 pm
PJR
 PJR
(@pjr)
http://uk.farnell.com/molex/39530-0002/terminal-block-eurostyle-2-position/dp/1368433
Peter
Postato : 03/08/2017 11:42 pm
