Heat Bed Problem
I've been doing a couple of test prints and have had a couple of issues with the heated bed. When I try and pre-heat for PLA the extruder is the only one that heats up and the heated bed doesn't. However I've had the heated bed start heating up sometimes after I auto homed the axis' and then went to print from SD without pre-heating. I checked the wiring last night and everything looked fine? I'm not really sure what the problem could be?
Re: Heat Bed Problem
Hi Nathan
Best bet - either cabling or fuse.
Take out the fuse (the 15A one) and check it for continuity with a multimeter.
Check the cabling - ensure the screws are really tight on the connector and that the connector is pushed well home.
With a multimeter, first touch the probes together and measure the resistance. Then measure the resistance of the heated bed - touch the probes to the screws on the connector. Take of the probe resistance and you should get a result of 1 to 2 Ohms.
Peter
Hi Peter,
Thanks so much! I'll get back to you and let you know what works!
Nathan
